Ir para o conteúdo principal
O headset Astro A40 TR é um dispositivo de áudio lançado em agosto de 2015, identificado pelo número de modelo 3AS48-XOU9N-601
Sound is severely distorted
One day I was playing rust, and then I looked left at my dog, and it tugged on the wire a little bit and then it sounded as if my astros were half plugged in, they were fully plugged in. I tried unplugging them or using them in a different device, but nothing worked. I could hear a little bit of sound, but it was severely muffled and distorted. Please help.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Probably bad sound cables or bad speakers
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@nathanfonk sounds like you pulled some wires either fully off the jack or it’s partially loose and they are shortening the sound out. Hence the distortion. My suggestion is that you open up the jack and check it out. Should be a straightforward replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Nathan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 2,243
