Ir para o conteúdo principal
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
iMac does not recognize WD Blue SSD
I have replaced the HDD of my iMac by a 1T WD Blue SSD, but the computer is not recognizing the SSD. I booted from a live linux CD and the drive is not showing up on for instance lsblk. Any help would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I would suggest to check the connection. And / or test the drive in another computer/external case.
por
Adicionar um comentário
1 resposta
This is the problem with the Fixed III SSDs in SATA II Macs like this - they do not work! You need a drive with a SATA II mode, or a Fixed II SSD.
As to what drives I’d recommend there are two:
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tsog Gantumur será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 268
