Ir para o conteúdo principal
The Kushlan Cement Mixer 1000DD-WB is a direct drive cement mixer with a 1.5-horsepower direct-drive motor. The mixer's polyethylene drum can hold up to 10 cubic feet or about 800 pounds of wet cement.
How to remove motor and gearbox from barrel?
1000ddwd kushlan mixer. Replacement gearbox received. Can't get the old box off the barrel. Have already removed the giant bolt in the spindle that should have freed the whole assembly. Do I have to tear this thing down to the nuts?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
Don’t know if this helps or not but here are the gear motor assembly instructions section of the user manual.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rob Turner será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 700
