Ir para o conteúdo principal
A segunda geração do Mitsubishi Eclipse, também comercializada como Eagle Talon; o modelo conversível era chamado de Spyder.
Car horn continuously going off
Similar problems have been answered on the internet, but not quite like this. So the car horn on my dad's 2006 eclipse started continuously going off the other night. I ended up disconnecting the battery to get it to stop. The next day I checked the fuses, pulled the relay (obviously stops the horn) replaced the relay still goes off as soon as the relay was plugged back in. If I disconnect the horn switch at the steering wheel the horn will still go off as soon as I put the relay back in. What's weird is starting the car makes the horn stop, and the horn when pressed works fine.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Don’t know the vehicle but I’m wondering if the problem is with the Central Door Locking System or perhaps the vehicle key fob.
Here are some composite images taken from the 2006-2012 Mitsubishi Eclipse & Spyder Service And Repair Manual Circuit diagrams and the 2nd Component Locations sections of the manual which show the two operate circuits for the horn, the location of where the two circuits are connected together and where the ECU is located.
Imagem
Imagem
(click on images to enlarge for better viewing)
Since you have proved that the steering wheel horn circuit is not the problem, the only other circuit for the horn is from the Central Door Locking System circuit which operates the same horn relay.
Not sure what you meant by “….continuously going off…”, whether this meant that the horn was on all the time or was sounding like a car alarm going on and off continuously, that’s why I mentioned the keyfob as it has a panic button which when pressed should activate the horn. At least I think that is what it does when reading the owner manual for the vehicle. Perhaps you could remove the battery from the keyfob and check. Just a thought.
If it is sounding continuously then you may have to check the circuit from or in the ETACS-ECU.
Hopefully a start.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Nathan slackway será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 30
Ao todo: 1,329
