How to replace spring tentioner s HP 4620
How do I replace spring tentioner s on the back inside of my HP 4620 printer
Esta é uma boa pergunta?
Hi,
Not sure which springs you’re referring to, but here’s a teardown video of the printer.
At 2:58 minutes into the video the two printhead tension springs are seen being removed by using a tool with a hook
At 7:36 minutes, one carriage unit spring clip is being removed. There may be one on the other end of the carriage.
At 11.57 minutes the feed roller spring is shown.
Hopefully this will help you to replace the springs.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 406
