Ir para o conteúdo principal
Screen Locked
PLz man tell me key of screen lock in ipod model:A1320
Esta é uma boa pergunta?
Pontuação 4
3 comentários
tonkas, there is no default "key" it works better if you ask your own question. Click on the link on the right side of this screen Ask a Question" and give as much detail as possible. Have you tried any of the above steps to unlock it?
por Compartilhar
Sorry mate, the code is personal. There’s no universal unlock code (except for erasing it)
por Compartilhar
Kaki otkljucati ipod A1320 Lea's
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
This is my answer for most of these disabled iPods. You can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared, again not sure if it works for a disabled one. Sorry if you use a Mac....can't help you with the steps on there :-) the other thing you can do, if you have the computer that you always use for this ipod, is to simply restore it
Esta resposta foi útil?
Pontuação 3
2 comentários:
If you have a Mac go into finder, select your iPod (choose the drive with your iPod’s name not the iPod icon) then press CMD+SHIFT+period to show hidden files, your iPod_control folder will be there
por Compartilhar
did not expect that to work but wow... it did
por Compartilhar
Adicionar a sua resposta
tonkas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 2,177
