Ir para o conteúdo principal
Why touchpad is not working?
My touchpad is not working also I have installed all the drivers which are required for touchpad I think it has some internal problem because it works some time and most of the time not works
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
What is the status of the touchpad in Device Manager > Mice and other pointing devices?
If listed right click on the Dell Touchpad entry > Properties > General tab and check what it says in the Device Status box.
If it is not shown under Mice and other pointing devices, click on Device Manager > View > Show hidden devices to check if it is now shown in Device Manager somewhere.
If the status is shown as OK in Device Manager as you say it may be a hardware problem.
Here’s the owner manual for the laptop. Go to p.32 to view the necessary pre-requisite steps and then the procedure to remove /replace the touchpad. This will enable you to firstly check that the touchpad cable connections are OK and if so you may have to replace the touchpad.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Muhammad Bilal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 15
Ao todo: 802
