Ir para o conteúdo principal
O HTC EVO é um smartphone da HTC equipado com um processador Snapdragon de 1 GHz e que utiliza o sistema operacional Android.
Stuck on bootloader screen
stuck on bootloader screen. when I try to re-boot it just keeps coming back to boot screen
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Solução escolhida
Try a Hard Reset.
Esta resposta foi útil?
Pontuação 3
1 comentário:
+ I like it when you talk like that. Ever thought of running for president?
por Compartilhar
Is the operating system stock Android that came with your phone?
If you installed a custom ROM, sometimes they can cause your phone to "boot loop" like that. Most of the time using a different kernel will solve the problem. That only applies if you're not using the stock operating system, though.
Pontuação 0
If you rooted the phone go into the root menu: With celll off hold down button volume tap power on while holding down. Go to recovery do a wipe cache then go to advance and do a wipe cache in your selected rooted. MOST of the time this will repair the problem.
Pontuação 0
step 1 turn off phone
step 2 count to three
step4 throw it as hard as u can at the ground
step5 pick up phone place gently in trash
step6 walk away.... lmao
Pontuação 0
Adicionar a sua resposta
steve será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Ao todo: 4,665
