Ir para o conteúdo principal
The LG Gram 15 (2016) is a premium lightweight laptop from LG, with a 15.6" IPS display and magnesium alloy body. Measures 0.7" thick and 2.2 lbs in weight. Model number: 15Z960-A.AA75U1.
11 Perguntas Visualizar todos
Spilled a little water and now 2 key and A key do not work.
So a day ago I spilled a little water on my laptop’s keyboard. I checked most of the keys and I found only 2 and A don’t work. Today I checked again and 3 has also kicked the bucket. Am I screwed or do I need something to dry the water? I haven’t tried anything except keeping the lid open and placing it upside down on a slant. Please tell me if I need to replace it or I can keep the current keyboard.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
According to the ifixit LG Gram 15" Repairability Assessment guide, there is a thin film insulator (see Step.8), between the keyboard and the rest of the internal components in the laptop.
You may be lucky that this has prevented the water getting through the keyboard and creating any more damage to the laptop.
If no further problems arise which may make it necessary to open the laptop and check for any water damage to the other components, then it may be worth trying to replace the faulty keys rather than the whole keyboard and see if that resolves the problem.
Update (07/17/2020)
Hi @Lord Aymor
You have to disassemble the laptop (user the teardown guide) and then remove all traces of water and any corrosion caused by the water by using Isopropyl Alcohol 99%+ (available from electronics parts stores).
Here's a link that may help with this Electronics Water Damage.
Also when opening the laptop, remember to disconnect the battery from the motherboard as soon as it is accessible so as to prevent or at least minimize any possible electrical damage to the motherboard when using tools etc to further disassemble and to clean. There is always power available on the motherboard even when the laptop is turned off as the power button is not a power isolating button. It merely signals the BIOS on the motherboard what is wanted. With any electronics repair it is always power off first, on last
If doing all this seems too daunting to do yourself, contact a reputable, professional laptop repair service, experienced in liquid damage repair and ask for a quote to repair the laptop.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Is the water out and if it isn't how can I get it out?
por
Okay A key came back on its own that gives me hope. I will tear down and use isopropyl alchohol will update when done.
por
Adicionar a sua resposta
Lord Aymor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 59
Duração total: 3,813
