Ir para o conteúdo principal
A small white or black laptop with the word Acer written in silver on the outside cover. The top has a woven fabric texture to reduce glare.
Is there a CMOS battery?
Hello !
I have an issue with my BIOS where i can’t change a thing in it and after several tries on installing different Linux distributions, it keeps failing to boot after the asked reboot at the end of the installation.
I can’t find the CMOS battery on my motherboard to hard reset the computer to factory mode, and I’m a bit ashamed lol !
If anyone can help me, i’ll take it ! Thanks in advance !
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Hello friend, did you find the solution? I have the same problem.
por
Adicionar um comentário
2 respostas
When the ACER logo appears, press and hold ‘‘Alt+F10’’ until screen changes. Hopefully you won’t need to dig for the battery.
Esta resposta foi útil?
Pontuação 0
3 comentários:
It doesn’t work at all ! This combination of keys don’t make a thing and I can’t edit anything other than the date / hours + the user password on the Bios, the others are grey
por
Then this seems to be an 1-way. Try to find a trustwotrhy disassembly guide for your acer. Blueprints are hard to find normally, so youtube might be the best choice.
por
That's why I posted here, I didn't find any blueprints or videos with my computer in two days lol !
por
These Acer "Cloudbooks" use a capacitor backed CMOS RAM, with a reference BIOS setting stored in NVRAM. If the machine has problems with saving BIOS settings, it is due to a bad primary battery, as it is held with a supercapacitor on these. I do not see a CMOS battery on the motherboard on this laptop.
Pontuação 0
Adicionar a sua resposta
Odasio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 864
