Ir para o conteúdo principal
Trackpad not very responsive
Hi all,
Jan 2009 15" MBP has recently begun to develop an issue with the trackpad - it requires a VERY firm push to register a "click". Running SL, started prior to the install.
I tried a fresh install but same issue with the trackpad - much less responsive than previously.
We live a couple of hours away from the nearest Apple store, so hoping to get some advice before we have to go to the store (have Applecare as well, will phone in first before hitting the store.)
Thanks in advance for any ideas!
Shel
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
6 respostas
Pergunta mais útil
I have an original MBP that did something like that... I put 2 stickey notes on the battery (spacing or insulation-not sure which) and reinstalled the battery. Works just fine now. Of course, mine is way out of warranty.
Esta resposta foi útil?
Pontuação 3
You'd need to take the bottom case off. First inspect the battery to see if its swollen at all. If not, there should be a tri-wing screw on the underside of the trackpad. Adjusting this can affect the click, you'll have to experiment a bit. And you'll need a tri-wing screwdriver obviously.
Pontuação 2
Unfortunately, your issue appears to be hardware-related, not software. I would call AppleCare and setup a mail-in repair - you will save yourself a long drive (or two), and the Apple Store is probably going to send it to the depot instead of attempting an in-store repair.
I just sent in a display, it was turned around the same day - the depots appear to be pretty efficient currently...
The unibody models are constructed from the top case down, making the trackpad and keyboard the hardest parts to get to - complete opposite of the PowerBooks and earlier MacBook Pros.
Pontuação 1
check here:
http://discussions.apple.com/thread.jspa...
Pontuação 1
I think that trackpad problems like this come with use of a laptop. The best fix would be checking the components under the click, the mechanism that registers your click. Apple might do this
Pontuação 0
My trackpad scrolls fine, and does all the gestures but is not clicking what is the problem? any advice?
Pontuação 0
Adicionar a sua resposta
Shel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 7,073
