Ir para o conteúdo principal
Power being received, no boot
I picked up this old macbook to try and repair. The power button does not work, but I am able to start the motherboard by shorting the pin on the keyboard connector. The fan spins up, and the charger LED is green. The battery is removed. beyond the fan I have no signs of life, no logo or keyboard lightup, and completely black screen with no lights. Looking for any suggestions to get this going, thanks.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
See if after you boot up the system if the backlight is all thats not working by aiming a flashlight through the Apple Logo in the lid can you see the faint image of your desktop?
At this point we don't know if you only need a new keyboard or something more.
por
no, i had seen the flashlight trick and tried it with no success
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Not good ;-{
That means you have both a keyboard and logic board failures. Consider the costs of the parts to fix this
Substituição da placa lógica do MacBook Pro 15" (corpo) monobloco 2,53 GHz meados de 2009
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ronnie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 250
