Ir para o conteúdo principal
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Perguntas Visualizar todos
Power being received, no boot
I picked up this old macbook to try and repair. The power button does not work, but I am able to start the motherboard by shorting the pin on the keyboard connector. The fan spins up, and the charger LED is green. The battery is removed. beyond the fan I have no signs of life, no logo or keyboard lightup, and completely black screen with no lights. Looking for any suggestions to get this going, thanks.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
See if after you boot up the system if the backlight is all thats not working by aiming a flashlight through the Apple Logo in the lid can you see the faint image of your desktop?
At this point we don't know if you only need a new keyboard or something more.
por
no, i had seen the flashlight trick and tried it with no success
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Not good ;-{
That means you have both a keyboard and logic board failures. Consider the costs of the parts to fix this
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Logic Board Replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ronnie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 31
