Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Perguntas Visualizar todos
How do I adjust the hinge on my display assembly?
I dropped my laptop and the lid is now slightly pushed forwards and it scrapes when opening and closing. I looked around for some solutions and guides on how to change/adjust the height of the display through the hinges but i can only find how replace the hinges which would not solve my problem.
Is this possible to adjust height or do i have to replace some part to fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Lossen the screws holding the display on as seen in steps 15-17 of this guide, realign the display, then tighten the screws back up.
MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
nak será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 216
