Ir para o conteúdo principal
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
20 Perguntas Visualizar todos
Why do my fans not spin?
So I've built my first PC, got it to post, currently installing Windows and the CPU-Fan is doing his Job. But my Case Fans just don't spin. I couldn't spot a mistake with the Cables so what could it be?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Hi,
What is the make and model number of the motherboard?
por
The Motherboard is an Asus ROG Strix. The Model-number is ROG Strix X570-E Gaming
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
If you have the motherboard manual check that you have connected the chassis fan(s) to D and or E as per the diagram on p.1-18
Then go into BIOS and set the Q-FAN Control for CHA1 Fan and or CHA2 fan, depending on what type and which fans you have connected as per p.3-7 (see p.3-3 for how to get to the Q-Fan Control in BIOS)
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks for the help, that actually worked!
por
Adicionar a sua resposta
Mutz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 2,399
