Ir para o conteúdo principal
Drone quadricóptero fabricado pela GoPro para filmagem aérea.
Main Board Chip replacement
Hello. I bought this Karma with everything for 150. However, I bought it broken. I located some broken chips. I am good and replacing chips, capacitors, resistors on boards, but I am terrible at the moment knowing what any of it means.
I supplied pictures, could you guys/gals let me know what these are and where I can buy them to reflow them onto the board???
https://ibb.co/BsFMDVp
Imagem
https://ibb.co/dDgKNSN
Imagem
https://ibb.co/bKj8J3W
Imagem
https://ibb.co/7GDbcK2
Imagem
https://ibb.co/f46wx3y
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
you would be better off just buying another one with the pairing issue cheap. The pairing issue fix has a very high success rate. That board could have other issues that you cant see.
Esta resposta foi útil?
Pontuação 0
Img #1 is a 15µH inductor
Img #2 is a 100µF 35V SMD electrolytic capacitor
Img #3 unable to determine if this is a bad connector or bad ribbon cable
Img #5 is a BSC0588- N-CHANNEL POWER MOSFET
Pontuação 0
Adicionar a sua resposta
rookerdesigns84 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 39
Ao todo: 312
