Ir para o conteúdo principal
Smartphone designed by Xiaomi in the Redmi Note line.
Dropped in water. Phone restart again and again
Phone dropped in the water. within second i put it out from water. And switch off phone. Next day morning i dry the phone. After that switch on phone but only mi logo appears and phone restarting again and again
so now what should i do?
Please help me.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @ashish97
Water, electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it has been properly cleaned away.
First do not try to turn on or charge your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion etc. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. You may also have to remove any shields covering the components as water may have got in under them. Also any flex cable ends/cable connectors will need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a video that shows how to dis-assemble the phone which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later,
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ASHISHRANOLIYA será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 1,734
