Lost Remote. Change settings
I lost remote for Sanyo tv.model #
DS25500 and need to change off Video 2 to regular analog tv with rabbit ears antenna
Esta é uma boa pergunta?
Hi,
Looking at the user manual there appears to be no options in the TV Menus to change the input source or even to reset the TV back to its’ factory default settings.
It has to be done by using the remote control unit (supplier example only to show cost of remote).
You could try a power refresh and check if this restores the TV to default i.e. TV antenna, but not sure if this will work.
Turn off the TV (if on) and then disconnect the TV power cord from the wall outlet. Press and hold the TV’s Power On button for 30 seconds and then release the button. Reconnect the TV power cord to the wall outlet and turn on the TV and check if the input has changed from Video to TV antenna.
A workaround if you have an old VCR which works with analogue TV signals is to connect the TV antenna to it and then connect the VCR to the Video 2 input and then tune the VCR to the TV channels and use it to switch channels for the TV
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 2,493
