electric aerial not working
hi my electric aerial has stopped workin since took battery off to re charge...any ideas...which fuse relates to aerial? 91 legacy
Esta é uma boa pergunta?
It does not appear as if your Subaru has a designated fuse for just the antenna. I would check on the radio fuse or look for an inline fuse. I attached part of the wiring diagram as an image. The complete wiring diagram from the service manual is available right here for you to download. Hope this helps, good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 1,477
1 comentário
i know this isn't aerial related but we had a similar issue with a sunroof and the battery issue. the solution was to disconnect the battery again and then it worked..seemed the cars computer had reset itself. might be a similar problem here?
por pollytintop
