Ir para o conteúdo principal
Um tablet e notebook 2 em 1 destacável fabricado em 2016 pela HP.
No Sound due to driver issue
I no longer get sound as it stating I have no audio output device installed. I’ve performed several refreshes of the complete system without any success The bios has been flashed and still no joy. Any ideas.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
Have you checked if there is a listing for "other devices" in Device Manager to see if the sound controller is there?
Have you selected Device Manager > View > show hidden devices, to see if it is listed there?
If it is listed in either place right click on the entry and select Update driver and follow the prompts and then check if it is shown in the Sound, video and game controllers list in Device Manager.
How did you prove that it is a driver issue and not an audio hardware issue, did you try the HP hardware diagnostics option in BIOS see user manual p.44?
por
Adicionar um comentário
1 resposta
Also check control center > sound devices and make sure its outputting to the correct device. After updates windows tend to change sound settings. If that doesnt work contact hp and ask for driver help
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Allun Seabourne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 1,244
