Ir para o conteúdo principal
The Inspiron 11-3168 is a laptop designed and distributed by Dell as part of their Inspiron range. The laptop was released in January, 2016.
2 Perguntas Visualizar todos
My battery doesn´t want to power my laptop.
A lot of times when I go to power my laptop up it just won´t turn on. Well I have had to open it up unplug the battery connector and re-plug it back in and then it works. Why does it do this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It sounds like one of the cells is dragging down the entire pack and you’re due for a replacement battery. You can find the battery here and the DP/N is 0JV6J. The guide can be found here.
If that’s too pricey for what I could immediately tell was a cheap laptop, there are aftermarket copies of the Dell battery out there for far less. Normally I don’t even mention this, but for yours I’m making an exception due to the cost relative to the low used resale value of these low end machines that are likely to contain eMMC. I still think it’s not a good idea for a good machine you paid a good amount for new, but I would get it if you put a knockoff in a cheap laptop like this where it was no more then $250, but between $150(Celeron)-200/250 (Pentium Quad).
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Keygun Cortez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 91
