Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
873 Perguntas Visualizar todos
It keeps shutting off after back glass removed.
I recently removed the back glass from an iphone 8. Before putting on the new piece I tested the phone. After showing the apple logo it automaticaly shuts off. Does anybody know what could be going wrong?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What you did? How you removed it? Hot Plate, Heat Gun, Laser or frozen?
Did you removed the motherboard before the process?
por
I used a heat gun and applied a very small amount of heat. I did not remove anything from the phone.
por
Adicionar um comentário
1 resposta
Solução escolhida
Doing a back glass removal without emptying the housing is a recipe for disaster. So much could be wrong it’s hard to know where to start.
I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, charging coil, front camera, rear camera and home button extension flex. Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer.
Does iTunes recognize your phone? If so, then you should re-connect one flex at a time until the phone stops working. I would start with the charging coil, then the Home button flex, then add the rear camera, LCD & Digitizer.
If the bare-bones setup does not get recognized by iTunes, then you most likely have a logic board issue. You could send it (or find a local) to a repair shop that specializes in micro-soldering repair.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Elijah Rene File será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 189
