Ir para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
digitizer ribbon cable ZIF sockets
Hi guys, I´ve followed your steps to change the ipad front panel but I messed up the “digitizer ribbon cable ZIF sockets” trying to “prying up on the hinged retaining flaps” Can I buy just that part? the front panel its perfect but i miss-understood the steps and broke those connectors…. Did I need a new complete logic board? thanks a lot!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Replacing those connectors requires some micro-soldering so unless you have experience doing this kind of work, it is not really a DIY repair.
A repair shop that specializes in micro-soldering repair should be able to do this for you. Depending on where you are located, you’ll need to consider if it is a worthwhile investment for such an older device. Alternatively, you may be able to find a used logic board for less than the cost of the repair.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks a lot!
por
Adicionar a sua resposta
joao será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 139
