Ir para o conteúdo principal
Support for the CQ57 series of Compaq notebook computers.
Why is screen totally black after turning on but capslock light is on?
When I switch on my laptop the screen is totally black. I have tried to fix by removing the battery and pressing the power button for 30 seconds but hasn't fix it. Please help me to fix this.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
connect a external monitor and check if you are getting anything on the display
Esta resposta foi útil?
Pontuação 0
This is usually loose RAM on an HP, or in some cases a failed module. Remove the battery, the main cover below the hard drive cover and reseat the SODIMM module/s. If it persists, they're bad and need to be replaced.
If neither of these help, the motherboard is dead - common on these "low cost" HP laptops.
Pontuação 0
Adicionar a sua resposta
Komal Agarwal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 204
