Ir para o conteúdo principal
Repair and disassembly guides for alarm clocks.
20 Perguntas Visualizar todos
AC 12V 820mA capatibility
I have a wall clock that says AC12V 820mA for the power supply. I need to purchase a replacement plug for a customer. DO I have to buy the plug that specifically says 820mA or is there a generic "output" that will work with this clock?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
What's the make and model number?
por
Adicionar um comentário
1 resposta
@teefowl no you do not. Without seeing which plug you are taking about (male or female end) it is difficult to know for sure what you have going. From your description “wall clock that says AC12V 820mA” it sounds like you are looking for a barrel connector. Those are not bound by the mA just by the counterpart (barrel size) of the plug. Post some good pictures of the adapter and the plug that needs replacing to verify this. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Travis Fowler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 77
