Ir para o conteúdo principal
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 Perguntas Visualizar todos
Broken leg on motherboard screen connector side
On the process of replacing touch screen one leg which connect the screw for screen connector has broken.
Now when assembled screen light up with apple logo and goes of dark continually going on. This is happening only when connected to power.
Is there any way to fix it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The boot looping was due to The poor contact on the power connector on the logic board, one small leg next to the negative contact was deformed and nor making contact with the battery terminal.
thaks for your replay.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
It’s hard to say from the pictures but if the device is boot-looping, then the standoff (leg) probably damaged some copper traces on the logic board when it was broken. If that’s the case, this will require a micro-soldering repair and is not DIY.
Can you post a better picture, up close so that we can see more detail of where the standoff was?
Pontuação 2
Adicionar a sua resposta
Kumar Nair será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 129
