Ir para o conteúdo principal
Processador dual core Intel Core i5 de 2,5 GHz (Turbo Boost de até 3,1 GHz) com 3 MB de cache L3 compartilhado.
Charge port replacement question
Hi,
My computer has had trouble charging. I replaced the charger (onE of the pins was stuck) but the problem has persisted. I noticed some burn marks on my charge port and and looking to replace it. Which charge port is the correct one? and which repair guide?
my macbook is a A1278 model, serial number is: C1MMHY1KDTY3
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
@tootscoots according to your serial number your MBP is actually a MacBook Pro 13-Inch "Core i5" 2.5 Mid-2012
2.5 GHz Core i5 (I5-3210M)
Intro.June 11, 2012
Disc.October 27, 2016
OrderMD101LL/A*ModelA1278 (EMC 2554*)
FamilyMid-2012
13"IDMacBookPro9,2
info from here which would make it a unibody model. Heerr is the guide for that Substituição da placa MagSafe DC-In do MacBook Pro 13" Unibody meados de 2012 and the part is available right here MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Imagem de Replace a damaged or malfunctioning magnetic DC power connector.
Produto
$9.99
Esta resposta foi útil?
Pontuação 1
Charging ports are easy to damage. Constant connecting and removal of the connector cord can be hard on the port and move, bend, or damage internal components. Sometimes a dropped phone can also cause charging issues. If your phone or mobile device has stopped charging correctly krogerfeedback
Pontuação 0
Adicionar a sua resposta
foster anderson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 391
