What SSD or SSHD can I use to update this iMac?
Hello all,
I have seen a lot of threads on here about changing the hard drive on these macs, but they are all old. Has the technology changed, or a consensus best option? I am looking for a 500GB SSD or SSHD to replace my hard drive. Please help!
Esta é uma boa pergunta?
7 comentários
Yes, the technology has changed!
But it all revolves around newer interfaces. SATA has been upgraded from your SATA II (3.0 Gb/s) to SATA III (6.0 Gb/s) and even that have been eclipsed with PCIe/NVMe M.2 blade SSD drives. So while SATA drives are still very much in use, you do need to be careful not to get a drive that won't play well with the older SATA II interface your system has. Make sure the drives spec sheet calls out the data rate 3.0 Gb/s if it doesn't look for a different drive. As an example: Seagate 3.5" FireCuda SSHD note it lists 3.0 Gb/s.
Now look at the Seagate 2.5" FireCuda SSHD drive note is does not list compatibility to the older SATA specs. This drive won't work in your system! So we need to be careful these days as the HD makers are dropping support of the older I/O speeds.
por Dan
@danj arent the SATA III backwards compatible?
por Mike
Well, Yes & No!
Strictly speaking the standard is written to allow older drives (SATA II) to work in newer systems (SATA III) not the other way around!
Some older drives had a jumper to alter the I/O to SATA I (1.5 Gb/s) these are long since gone! And besides, who wants to buy a SATA III drive and push it down the SATA I in a SATA II system when cheaper SATA II drives where available.
A good way to see this is think how a gallon jug of water can't fill the quart bottle without spilling, but the quart bottle of water can fill (partly) a gallon jug!
We use the terms Fixed and Auto to help in discussing why some drive do work!
So to be clear a Fixed speed drive is just that one and only one I/O speed, and these will only work with systems that are equal in spec or the spec is greater. So a Fixed SATA II drive will work in either a SATA II or III system.
Now an Auto speed drive has circuitry to identify what the system is able to support of its I/O data feed and match it!
So if you look at the two spec sheets I posted the 2.5" drive is Fixed and the 3.5" is Auto. As Seagate pulled the logic from the 2.5" drive to be price competitive as well as the need for older spec'ed drives is waning.
por Dan
@danj I wouldn't even trust II/III Premium drives in a machine like this - autosense only.
por Nick
I've never heard of a II/III premium drive.
It's either a Fixed or Auto Sense drive. The ability of the drive to be faster gets into the RPM of the disks motor, If it has a SSD cache onboard (SSHD), and being disk (HDD) vs solid state (SSD).
The spec sheet for the given drive is what I go by. If it's not clearly spelled out its not on my radar.
por Dan
Exibir mais 2 comentários
