Ir para o conteúdo principal
Apple iPad da primeira geração, disponível nas versões Wi-Fi e 3G com 16, 32 ou 64 GB de armazenamento.
Screen not rotating when device turned
Suddenly my screen won't change from portrait mode to landscape when I turn the device - only showing in portrait even when turned sideways
Update
Thank you, nicksmacandpchelp and oldturkey03! Got it! :)
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Try turning device off then powering on, may need just to reset itself
por
Isn't there a switch by the volume that locks it into place? Have you checked on that and make sure it is properly set.
por
Adicionar um comentário
2 respostas
Solução escolhida
On the side, like the iPhone, only the iPad's locks the rotation, reset that to unlocked and that should do it
Esta resposta foi útil?
Pontuação 0
I have noticed this problem too while using some apps like SKYPE on the IPAD2. When ever an app like SKYPE is crashed or closed. The screen tilting is not working. I think if you restart the device, this is not repeating. This may partly answer your question. But this is what i have identified so far.
Pontuação 0
Adicionar a sua resposta
Shannon Swift será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 1,358
