Ir para o conteúdo principal
Guias de reparo e suporte para laptops de 17" da série HP Pavilion Notebook 17. Estes laptops possuem números de modelo de 17-g000 a 17-g099.
CPU Fan not getting Power ( Fan Works ) HELP
Hey Guys,
Pav 17-e118dx
I picked this laptop up to do some maint and sell. The Fan was extremely noisy so like usual I took laptop apart and replaced the fan, when i replaced the fan i replaced the thermal paste with better aftermarket paste. Everything seemed to go smoothly . I booted it up and got the cpu fan error . I verified the fan was working by taking it back apart and hooking it to a small power source. Spins good sounds good. I put back together and it still wont spin . These are all the avenues i have gone
Bios checked fan always on - toggled it on and off both have no change
Removed the battery and all power source- Hoping i could get a reset to maybe something in the firmware
Hooked another fan up ( nothing no spinning )
Hardware is a Fan specific to that build if anyone wants to know.
Ive repaired thousands of laptops and im scratching my head on this one. Flashing the bios help? Updating? Could a sensor be shorted out? What are my options!
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@holmesit check the fan connector to see if it even switches the fan on. Sounds like a bad “sensor” or “tach” on this. We would need to know the exact motherboard in this HP. Check for make/model/serial number or anything that may help us identify which board this is.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jon holmes será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 445
