Ir para o conteúdo principal
Screen Won’t turn on after repair
Was trying to replace the screen, but it doesn’t turn on. The phone vibrates as if it’s on, but the screen doesn’t seem to turn on, this cable seems ripped, is that enough to make the screen dysfunctional?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The picture is a little blurry so I can’t say for certain but even the tiniest tears in the flex can cause issues.
It’s very important to always disconnect the battery before disconnecting/reconnecting the screen assembly. The issue is that the LCD connector has pins that have high voltages (i.e. the backlight is ~20V) and ground in very close proximity. When you fumble around trying to line up the connector plug to the receptacle, you can short out the voltage rail and cause damage to the components in the backlight circuit. If you’re lucky, then only a backlight filter is damaged but other times, the entire circuit could be affected. Either way, this type of repair requires micro-soldering and isn’t really a DIY repair.
To test for this, plug your device into a charger or an iTunes enabled computer. Then shine a bright flashlight on the screen. If you can see a dim image, then the backlight circuit has been damaged. If you can’t see an image at all, then it may be the LCD circuit that is damaged.
You can connect the original, cracked screen to confirm this. If the original screen has the backlight on, then the replacement screen has an issue. If the original screen also doesn't show the backlight, then the backlight circuit is blown.
If iTunes doesn’t recognized the device than the problem is more than just a screen or backlight issue.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Yup, the backlight is broken. I tried skimming a flashlight at it and I could see a dim picture on the screen. Should I get a new screen since this it can’t be fixed?
por
Did you disconnect the battery before replacing the screen? If not, then it's probably a logic board issue.
por
Adicionar a sua resposta
123 123 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 44
