Battery drain with LCD connected
Hello there, I have a problem with iPad air 1. It is a little bit strange but when I plug LCD it drains battery.
Example: Yesterday I charged it to 100% and I didn’t use it at all, today battery is dead so I disassembled iPad and started to look for fix.
I plugged in a power supply to check if it takes any power and with board taken out of ipad when I connect only board to power supply it takes 0 Amps but when I turn off PS and connect LCD it takes 0.15A just with plugged in LCD, battery cannot be charged because of this drain and I have to charge battery with LCD unplugged. LCD is not a problem because I’ve checked with 2 others and problem is same, something is taken 0.15A out of battery constantly when LCD is plugged into board.
Do you have any suggestion what can cause this kind of problem ? Thanks a lot for any help
Esta é uma boa pergunta?
