Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
Touch issues after screen replacement
Replaced the screen on my friend’s phone and everything’s working EXCEPT after it’s been on for a couple hours, swiping up from the bottom (for the control center) and down from the top (for the notification center) stops working.
I plan to open it up and check the connections but I just wanted to see if anyone on here is familiar with this specific issue.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
This is most likely a poor quality or defective replacement screen.
Esta resposta foi útil?
Pontuação 2
2 comentários:
i ordered the screen from ifixit, is this known to happen from time to time?
por
Yes, dud screens will always filter through. Contact iFixit support and they will take care of you.
por
If you are sure that the screen is a reputed one, remove the screen flex and rearrange and install brackets(assuming if you missed it in case). Lock the flex cable carefully.
Pontuação 1
Adicionar a sua resposta
thardee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 24
Ao todo: 212
