Ir para o conteúdo principal
O RCX 1.0 é o primeiro modelo da linha RCX de blocos programáveis Lego Mindstorms.
How to fix RCX 1.0 I.R. problem?
The LEGO RCX 1.0 powers ON and all built-in programs work well. But when I tried downloading or even communicating with the I.R. Tower, the RCX wont respond! =(
Which component should be replaced or re-soldered? Please anyone... help pls. I just need to know.. which hardware component is at fault... so I can fix it.
Thank you =)
Esta é uma boa pergunta?
Pontuação 1
3 comentários
hello, i have the same problem like sirgilberts.
My RCX 2.0 shows a icon for IR detection and my older RXC 1.0 doesnt react - i have three of them but they wont work.
por
I'm working in a Schoolboard and i have 6 RCX 1.0 bricks with the same problem. I am interested if someone finds a solution.
por
The main problem is that Windows does not recognize the IR tower. This happens with versions newer than XP.
por
Adicionar um comentário
1 resposta
Solução escolhida
http://www.squidoo.com/collected-info-on...
it sounds like it may be a software problem, make sure you're up to date with any drivers for your console
Esta resposta foi útil?
Pontuação 1
1 comentário:
also take a look on here http://messageboards.lego.com/en-US/show... for some more ideas.
por
Adicionar a sua resposta
sirgilberts será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 26
Ao todo: 3,223
