Ir para o conteúdo principal
Repair information for graphic tablets. Graphic tablets are also known as digitizers, drawing tablets, drawing pads, digital drawing tablets, pen tablets, or digital artboards.
How much does it usually cost to replace a damaged screen?
The screen has been cracked, with it spider webbing across the whole tablet, want to know approximately how much it would cost to replace & what kind of places can do it as we’re in Australia.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
lonestarhellion  all of this will absolutely depend on the make and model of the tablet. We could not even begin to guess since there are vast differences in cost for a replacement and labor between makes and models.
Update (01/12/2020)
lonestarhellion you got a really good (expensive) tablet there. Before anything else you may want to give Wacom a call and see what they tell you. It is not going to be cheap based on the quality of your panel. https://buywacom.com.au/support
Esta resposta foi útil?
Pontuação 1
3 comentários:
It is a Wacom Cintiq 13HD if that helps any
por
Hi,
Has the tablet got a model number, eg DTK 1301/K0 or something similar?
Try searching for Wacom (insert model number) LCD screen part" and check for suitable results
Alternatively it might be easier if you dis-assemble the tablet and find the LCD screen part number on the back of the LCD panel and then search online using the part number only..
It may be a pain to do this but it has its' advantages. You know that you will be getting the correct part if you find one and also the part itself may be used in other devices so you may get results for more suppliers than if you just search for Wacom parts.
por
Thank you very much, am much obliged, will look into that.
por
if the screen is damaged you may can buy a new one, it may cost a lot to repair it because you may need to send it back to the manufacturer .
Whether you're looking for a graphics tablet or a drawing monitor , there are lots of options on the market, and they are probably all pretty compelling. It's easy to feel overwhelmed by the abundance of options.
Two particular heavyweights are Wacom and XP-PEN . Both manufacture graphics tablets and drawing tablets and have different strong and weak points. While XP-Pen tablets are generally cheaper than Wacom tablets and have more features, Wacom tablets tend to have more of a premium and durable build, and a lot more brand recognition.
Whenever and whatever you wanna buy for your personal or professional uses. But the price of the products has a great role when you compare some similar products, so if your budget is tight then, you should definitely go with the XP-pen artist series ( https://www.xp-pen.com/series/Artist-dis... ) .
Pontuação 0
Adicionar a sua resposta
lonestarhellion será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 2,386
