Samsung tab S2 lcd replacement
can I used another lcd screen from a S2 to replace one that has lines on it?
Esta é uma boa pergunta?
@dhn yes, you can replace the LCD’s from one S2 to another S2
Esta resposta foi útil?
Thank you for your quick response. Are you 100% sure ? Just asking because a local shop here said no and they charge $275. I can easily find a good use one way less than that
Yes you can use one from an S2 to "transplant" to another S2. They are not really easy to remove but are identical for all S2. Usual replacement is with the frame and cost for a replacement is around $150-$200 USD. To replace it follow something like this video https://www.youtube.com/watch?v=MSG67j-J...
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 350
1 comentário
use a lcd screen from one TAB S2 to replace a burnt screen on another Tab S2 - is it possible?
por Don
