Ir para o conteúdo principal
12.1 megapixel digital camera with 5.1x optical zoom.
6 Perguntas Visualizar todos
Can I wire the shutter for firing the camera from a distance?
I have a number of W-290’s and I would like to set them off simultaneously. Can I teardown the camera to the shutter button and solder wires to that shutter switch and drag them outside in some discreet way so that I can operate the shutter from a distance?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thank you! I haven't opened up any of the cameras yet, but I hope to do that this weekend. I'll post pictures when I do. I'm so grateful for your help.
por
Adicionar um comentário
1 resposta
Solução escolhida
@larryeda looks like you could solder two wires and a remote switch to replace S102 on the ST-208 board.
Post some good pictures of that board with your question. That way we can most likely point out where to solder the wires to. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Larry Heyda será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 66
