Where can I find bottom screws?
All I am looking for is just one long screw that is suppose to go at the bottom of the unibody macbook pro 13" early 2011. Where can I buy just one screw? Thank you!
Esta é uma boa pergunta?
The Genius Bar will probably have some off a junked laptop from a customer. I would try your luck there. If not, they have them in the back.
Esta resposta foi útil?
If Nicks answer fails, here's the whole set: MacBook Pro 13" Unibody (Early 2011-Mid 2012) Screw Set
you can put some of the non permanent lock-tight on the screws before you install them
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,704
1 comentário
Thanks guys Ill go give it a try!!!
por Louis Lu
