Ir para o conteúdo principal
Lançado em junho de 2016, identificado pelo número de modelo A3003 na Europa, A3000 na China e na América do Norte (de acordo com https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Digitizer does not work after screen replacement
I replaced screen and digitizer and it seems everything went fine. The phone turns on but the touch doesn't work, the back and all app button do work. I tried doing a factory reset but it stills doesn't work. What could be the problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Neil,
I would suggest disconnecting and re-seating the display cable. Carefully check the connector for any debris—the pins on the connectors are tiny.
Substituição do conjunto de tela e digitalizador do OnePlus 3
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hello Arthur,
I tried disconnecting and re-seating the display cable as you suggested but still nothing. Could it be a motherboard problem or should I send back the display+digitalizer and try with another one?
por
Hey Neil,
It could be a motherboard, though I'd think that the display may have a slightly higher chance of being the problem. Does the original screen work enough to be used as a test? Unfortunately with how the replacement is set up, it's not easy to swap displays.
por
Adicionar a sua resposta
Neil Considine será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 521
