Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
iPhone 7 water damage not turn on
Hello. I have a problem with the flooded iPhone 7, it had a short circuit of 0.350a I was able to remove it now it is 0.000a after turning on nothing happens and stands at 0.060-0.080a. Have any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
you need to clean it using isopropyl alcohol. that will involve completely disassembling it.
Electronics Water Damage
iPhone 7 Rear Case Replacement (you do not have to replace the rear case, but this guide will go over complete disassembly.
Esta resposta foi útil?
Pontuação 1
2 comentários:
pcb I already cleaned in an ultrasonic cleaner. A few capacitors fell in and there is no pmbb layout because it was short
por
@dxwxd ah, apologies. This is probably beyond my scope. @refectio could probably help here.
por
halo cześć,
0,06A przy starcie wskazuje na niski bilans energetyczny. W takich przypadkach warto przestudiować linie główne zasilania. W większości przypadków, jeśli ich parametry mieszczą się w normie szukałbym “korka” za PMU. Sprawdź porty LDO z MPU i CPU razem z liniami SOC. Niewiele dalej, bo od 0.09 zaczynają się spięcia pod procesorem, spowodowane przegrzaniem 7-ki przy zdejmowaniu shield’ów.
pozdrawiam,
Pontuação 0
Adicionar a sua resposta
Dawid Wojtyła será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 98
