Ir para o conteúdo principal
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
Are there no series 3 42mm gps only screens?
I need to replace the screen for my 42mm series 3 gps only watch but I can only find the screen for the LTE version. Are they currently out or something?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
You’re in luck! This website has the replacement part you need!
Apple Watch (42 mm Series 3 GPS) Screen
The kit has every part and tool needed for the job! I would also recommend getting the 42mm series 3 screen protector as well, this will prevent further damages. It may seem bulkier, but worth it in the end.
Imagem de Replace an OLED screen compatible with Apple Watch 42 mm Series 3 GPS Only Model A1859 smartwatch. Ion-X Glass and digitizer.
Produto
$129.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ali Jahromi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 328
