Ir para o conteúdo principal
Reparo e informações para o Dell Alienware 15 R3, um laptop gamer da linha Alienware.
Screen flickering right part of the screen
Hello , I have a problem with my laptop i don’t know what cause this problem and i just wanna know if this a software problem or hardware problem maybe cable or the entire screen is now broken
here is the video showing the screen problem Video 1 Video 2
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Try connecting an external monitor to the laptop and check if its display is OK.
If it is then you may have a hardware problem.
It could be a loose video cable connection to the systemboard, a faulty video cable (trying pressing on the left hinge area to see if you can make the problem come and go) or a faulty LCD panel.
Here’s a link to the service manual for the laptop.
Scroll to p.85 to view the necessary pre-requisite steps and then the procedure to remove the display assembly.
This should give you access to view the cable connection first.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Amr Fakhri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 1,648
