Ir para o conteúdo principal
O Dyson DC44 Animal é um aspirador de pó sem fio da Dyson, especializado na remoção de pelos de animais de superfícies domésticas. Número do modelo: DC44 Digital Slim MK2.
brush Head not turning
The brush head on my dyson is not spinning. No blockage or tangles. Think it’s the motor. Is this repairable?
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Hi,
With the brush head removed from the vacuum cleaner, do you get sufficient suction at the end of the rod that it attaches to?
Is the battery fully charged?
Is the filter clean?
por
Does anyone know where to get a replacement motor?
por
For parts from my experience eBay is 9/10 the best place
por
Adicionar um comentário
1 resposta
If the suction is ok, its probably due to hair being caught under the motorised head rotator.
  1. Take out the brush
  2. With a hexagonal screw driver head, not sure what size to be honest, remove the screw from the center of the rotator.
  3. Lever out the rotator.
# Use a pair of tweezers to remove any hair, you’ll be surprised as to how much there is.
  1. You may have to add a little grease
  2. Replace rotator, tighten up screw. Ensure it can turn manually.
  3. Test by attaching to battery and pulling trigger.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I have this problem but the brush is clear. It appears the power for the little electric motor is not being sent by the main unit down the two pins. How do I get inside to see why power isn’t getting through?
por
Adicionar a sua resposta
Joanne McGrath será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 2,984
