Ir para o conteúdo principal
Tablet Android lançado em janeiro de 2015. O Dell Venue 8 7840 possui um display de 8,4 polegadas com uma resolução de 2560 pixels por 1600 pixels.
Screen Tearing and Low Battery
NOTE: Not a Dell Venue 8 7840
Hello, Recently bought a Used Dell Venue 5050 (Not Pro) it booted up fine then Last Night i started getting Screen Tearing wondering if its the battery or the O.S.
Also its running android Lolipop
And Battery was only holding 25% Charge as of Last Night
Thanks in Advance, Andrew
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@born7 screen tearing should not be a battery issue. That is usually caused by the OS and/or memory. Try to charge your battery completely and then reset your software.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Then what would you recommend how do i run tests for bad memory or O.S. on Android or do i have to connect it a computer and factory reset it
Also how do you go about factory resetting this model of Dell Venue (5050) (Non Pro)
por
@born7 for a reset, this should work for your tablet. https://www.hardreset.info/devices/dell/...
por
now this "Battery was only holding 25% Charge" could definitely be a battery issue.
por
Adicionar a sua resposta
Andrew será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 300
