Ir para o conteúdo principal
A 6ª geração (E90 do carro compacto mais vendido da Toyota. Também vendido como E90 Sprinter, Holden Nova e Geo Prizm. Esta geração foi a última do Corolla a ser classificada como um veículo subcompacto e o primeiro Corolla exclusivamente com tração dianteira ou tração nas quatro rodas (a opção de tração traseira foi descontinuada nesta geração).
this is my problem
first problem of my corolla Toyota is grounded, the battery is becoming weak when engine stop. i used to recharge my battery everyday. when i start, it will start, but when i did not start the engine within three days, the battery would weak and cannot afford to start the engine. until now ,its about one month that the engine did not start. please advise me on how to repair
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
i dont know on how to answer my question.
por
Hi,
If you can charge your battery enough to start the car, once the car has started use a Voltmeter to measure the voltage across the battery terminals with the engine running.
It should measure between 13.8 -14.5V DC.
If it measures less than 13.8V DC then there is a problem either with the car's alternator or voltage regulator and the battery is not charging when the motor is running.
If it measures more than 14.5V DC it is overcharging the battery which could damage the battery.
Be safety aware when you do this as the engine is running!
Also ensure that the emergency brake (hand brake) is firmly applied
por
My Engine not start.please help me
por
Fuel tank is full of soil and rocks
por
Adicionar um comentário
1 resposta
We need the exact year of your car, also the battery may be shorted internally or have a dead cell so you should charge it up fully, to save time, then take it to your local auto parts store for a free test. If it is good then we can help you find the parasitic drain in your car. This test will involve an amp draw test which will use a multimeter, do you have a multimeter that can test amps? If you have one, do you know how to use it properly to test amps? Here is some help.
https://www.youtube.com/watch?v=KF1gijj0...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Teodoro Achas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 904
