Ir para o conteúdo principal
O Alienware M14x é um notebook projetado para uma experiência de jogo e conteúdo otimizadas.
Laptop GPU reflowing- help needed
Hi I want to reflow the gpu on my only laptop by myself, I can't trust repair center or can't effort a new laptop .
I kind of bent the main board so this happened.
Question : I want to reflow gpu using heat gun and laser thermometer for measurement , what's the best melting temperature for it? I saw people go up to 260 but I usually solder joints melt at 200-210 Celsius , so I'm wondering if lower temperature will reduced the risk of burning the gpu completely…
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@javid_zare_s a reflow is not going to fix a bend motherboard. If the solder connections or pads have come loose they will not go through a reflow. Remember that a good reflow is more than just blasting an area with a hot air gun. Anyhow, I suggest you follow the profile as outlined on here
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Javidzed será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 709
