Ir para o conteúdo principal
Portable Bluetooth speaker released in June 2015. The speaker features ClearAudio+ Technology and LDAC Technology. Model Number: SRS-X55.
9 Perguntas Visualizar todos
My adapter is broken on my speaker
The yellow part where you charge the Sony SRS-X55 is broken. How can I replace this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Darla Dang that is your DC in jack. It is soldered to the I/O board. Remove that board by using this guide Then check if you can unsolder it and find a replacement based on the dimension from places like mouser. com or digikey.com etc. Not a terrible complicated repair but it does require some soldering skills.
You can get the jack connectors from here https://ru.aliexpress.com/item/202656625...
Esta resposta foi útil?
Pontuação 1
The port the charger goes in the pin has come off the male component that's inside the speaker so I think I need a new connector so then I can charge as normal cheers
Pontuação 0
Adicionar a sua resposta
Darla Dang será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 455
