Ir para o conteúdo principal
Sony SRS-X55 I/O Board Replacement
O que você precisa
  1. Sony SRS-X55 I/O Board Replacement, Battery: passo 1, imagem 1 %32 Sony SRS-X55 I/O Board Replacement, Battery: passo 1, imagem 2 %32 Sony SRS-X55 I/O Board Replacement, Battery: passo 1, imagem 3 %32
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
  2. Sony SRS-X55 I/O Board Replacement: passo 2, imagem 1 %32
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
  3. Sony SRS-X55 I/O Board Replacement, I/O Board: passo 3, imagem 1 %32 Sony SRS-X55 I/O Board Replacement, I/O Board: passo 3, imagem 2 %32
    • Remove the two Phillips screws from the I/O board.
    • Remove the front panel to the speaker by pushing on the two tabs in the corners.
  4. Sony SRS-X55 I/O Board Replacement: passo 4, imagem 1 %32
    • Disconnect the ribbon cable from the I/O board.
    • Carefully remove the I/O board from the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Where can i get a new i/o board?
Kyle Workman - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 2,534
