My keyboard stopped working for certain keys
wyuiopshjklxnm
These are the only keys that work on my device tried to power wash and reset all settings
Esta é uma boa pergunta?
wyuiopshjklxnm
Hi @lordtrentonian ,
it looks like a connection between keyboard and motherboard is corrupted. I suggesting you disassemble your device and check the connection of mentioned HW. It may be only dust on the connectors or something same.
Esta resposta foi útil?
@lordtrentonian If not this simple repair of cleaning, then it most likely will need a new keyboard, get the numbers from the backside before you order a new replacement, hope cleaning it will take care of the problem.
I have the keyboard connector exposed. Can you or someone show me how to disconnect that wide ribbon connector so I can clean it and reseat it? I've never worked with this kind of connector before.
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 1,724
Power key and backspace key stop working
por David Hall
