Ir para o conteúdo principal
Repair guides and support for televisions manufactured by Sony.
750 Perguntas Visualizar todos
No sound on Sony TV XBR- 65X900C
Sony XBR- 65X900C - Model BRAVIA 4K 2015 - Version 7.0 - Android Security Patch Level May 1, 2019
the sound will just stop . Picture stays. Last night stopping after about 30 minutes of watching. The only fix is to turn off the TV . Wait a bit and then turn it back on.
Software is updated -
appreciate any help or advice.
Henry
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@pmcleod try an external speaker/soundbar/headphones and see if that makes a difference. Since you already updated the software etc. It is possible that this is an audio IC issue on the main board. Try a local input source like a DVD or BR to see if that works better. If so you need to check your video in source like cable box or sat receiver etc.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Phiilip Henry será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 179
